TwinTurbo.NET: Nissan 300ZX forum - Try new plugs. You have an inductive timing light, correct?
Subject Try new plugs. You have an inductive timing light, correct?
Posted by ZaXxon on June 16, 2013 at 8:37 PM
  This message has been viewed 289 times.
In Reply To new motor, new problems posted by youngbloodz on June 16, 2013 at 07:46 PM
Message Put the pickup around the #1 wire coming from the PTU.
Do you have a way to run diagnostics through consult? You need your base timing so you can match up your CAS.
Get a new alternator and battery and triple check all your grounds. Report back.
